21 - 40 of 44 Posts
2021 Sportsman XP1000S
By the way when I had my wreck 2 xp 1000’s said the simplest most impactful thing ! LOL
“ Slow Down “
LOL
So Polaris NZ :
you’re waiting for some parts now ?
Polaris Outlaw 500
Discussion Starter · #26 · (Edited)
So Polaris NZ :
Yeah wanting on aftermarket parts:
Grab bar
Pro Aluminium Front bumper
CFM airbox
CFM oil tank
CFM Air scoops
Modquad brake reservoir
Aluminium coolant overflow tank
Did get some parts. Choke parts, Battery strap parts, Rubber mounts for exhaust and the rubber part for bottom of air-box drain to replace the bit of green garden hose lol. New gear lever to replace stock loose aluminium one, Aluminium fuel cap for bling, P clams for custom skid plates on A-arms.
152344
152345
152346
152347
Still need to order some bushes and other small parts to service things that not be done in a long time. Nerf bars have been ordered. Have a document on my computer of parts I need to get and parts I may get that are just for looks. Going to be a long build but will get there.
Wow yeah , that’s nice you’ve got most of it at least figured out .
Reactions: PolarisNZ
Did you post about the custom skids already ?
Polaris Outlaw 500
Discussion Starter · #29 ·
Yip
Sweet
Chrome ?
Oh cool it’s polished aluminum. Nice
Polaris Outlaw 500
Discussion Starter · #36 ·
Got the radiator air scoops, air-box and rear brake reservoir test fitted. Oil tank not yet as I need to get the 2 rubber grommets for the bottom mounts as mine are old and cracking. Also started modifing the rear grab bar by moving it in closer to the bike by 35mms did the same on my Yamaha blaster & warrior when I had them, Get photos tomorrow.
154547
154548
154549
154550
154551
Polaris Outlaw 500
Discussion Starter · #37 ·
1st off the airbox did not fit. seat would not install properly without forcing it. Have worked out a way to fix it and the mounts are 20mm out from the factory.
This shows how much I had to lower it. Shocking isn't it.
154612
onto the good things now. I got the rear grab bar shortened. 35mm closer into the quad.
154613
Removed the extra mounting hole and angled the top to make look stock. Also cnc cut the 2 notches in the top to make clearance for the rear fender as it was sitting on it and forcing the fender up.
154614
CNC goodness.
154615
154616
Next will be to finish the airbox mounts. and to cnc cut some spacers for the rear grab bar.
Polaris Outlaw 500
Discussion Starter · #38 ·
CNC cut some parts for my quad today.
154665
Grab bar spacers installed.
154666
New rubber boot plate made.
154667
Radiator plates made. To fix the holes in the plastic from blowing out as 1 has already. This plate will stop that happening and clamps it all nice and tight to the CFM scoops. Still need to trim off the plastic tab on the side of the grill so it clears the scoops.
154668
154669
Getting some bolts and nuts tomorrow for the airbox.
21 - 40 of 44 Posts
