You thoughts or questions are welcome.
Actually that is incorrect information. The stock snorkel faces backwards. This adapter does NOT impede on the steering in any way and doesn't come close to me in the rider position.Great looking fabrication job...... and take my following advice for what it's worth.... possibly nothing!As I don't play that game and use my land machine as a submarine. But maybe my thoughts will help aid your thoughts. No harm intended, just throwing out idea's here.....
To me it looks like it would be in the way of bars and your arms when turning (stuck, wiggling/rocking machine, ect.) and maybe a crotch banger?
Is part of the problem with snorkels the fact they are always rear facing? :dunno: I understand this is to aid with water intrussion..... but, when rear facing they won't "scoop" the air like the stock designed does (forward facing), but rather create a vacume on the air box chamber, causing rich conditions as your experiancing (as when air moves past a rear facing opening it will pull air from that opening, not allow air in as desired!!). Forward facing would allow the air to be forced in and function as designed. Correct? Is there a way to make this forward facing, but create ducting (flow path) to keep water out? Possibly a forward facing opening that had to flow upward, before flowing downward. Like many of the PVC style setups seen installed, but NOT REAR FACING??
Again, just throwing out thoughts and obsevations of the "game".... :idea:
Okay, just basing my thoughts off my Value line design, not familiar with the XP direction of air intake. But the principle still stands true of rear facing, possibly creating a vacume effect. Did you test the std air box on the dyno? Be interesting to see if it too was lean! :dunno: Still think forward facing would yeild better results.Actually that is incorrect information. The stock snorkel faces backwards. This adapter does NOT impede on the steering in any way and doesn't come close to me in the rider position.Great looking fabrication job...... and take my following advice for what it's worth.... possibly nothing!As I don't play that game and use my land machine as a submarine. But maybe my thoughts will help aid your thoughts. No harm intended, just throwing out idea's here.....
Thank you, the stock cowl faces backwards and is more restrictive. The photo shows that.Cowl induction hoods face backwards and they have worked for years nice craftsmanship btw I like it
Looks good, nice fab job. Hope it improves your intake and lean condition.... do you plan to dyno this one soon?You thoughts or questions are welcome.
Its outerwears. I need to figure out a way to put outerwear on my intake too. :cowboy:Is that some type of filter cloth zip tied over the clutch vent tube ends/openings?
Thank you, I rode it around the yard and down the street. We are good to go, no issues at all and the machine runs much better than with the old snorkel kit. I saw one guy on here said there wasn't much room for a snorkel kit on the XP 1000 Scrambler. Maybe my adapter is the keyCame out really nice man, and its actually tucked in there pretty good...Shouldn't get in the way at all.
