· Registered
Hi everyone purchased new 2019 570 and just looking for tips on engine break in mainly from rpm limits and speed limits thanks guys I know their are many threads for this but none seem to mention rpm limits and speed.
· RIP 12/21/22
Unless you're a speed demon who likes to run everything wide open, just ride it normally with no WOT or long idle times and it will be well broken in within the first tank of fuel. Its not rocket science and there is no secret formula. Simply treat the machine well for the first little while and it will be fine.
· Administrator
I say you can give it full throttle, just don't hold it wide open past about 5000 RPM - when you hit 5000 RPM shut the throttle completely - I tell people to 'pasture ride' it for the first tank of fuel - you want to accelerate and decelerate - heat and cool - no high RPM and no extended idling - heating and cooling cycles are as important as run time
· Registered
Thanks great advice I've been running its through it paces. only 1 hour on it so wanna make sure I break it in right!
