"Do you think you could lift the machine by it or use it as a anchor for someone to pull you out with or tie the machine down by it?"
Personally, I did NOT purchase the brush guard as a towing or lifting accessory. As designed, the guard is made to protect the front of the machine, etc.
The guard is constructed of heavy tubing which extends out on both ends from the frame mounting plates. The mounting plates are fastened directly to the front frame members. As stated above, pulling on the center cross members escentially would be pulling on the main machine frame. I would NOT hook to or pull on the outer ends of the guard since they are not supported on the extreme outer ends, only on the center frame mounting plates, nor or they designed for that (pulling) purpose.
