Heys guys I'm new to this forum. I have been on the High Lifter forum for a while but with this paritcular problem I havent got an answer on there. Heres the deal. I just installed a QSC mud pro clutch kit on my 2010 850. It has a 2400 rpm stall on it. I finally got some good riding time on it this past weekend and when I got back sunday i noticed something. When I now put it in gear on flat ground the bike will begin to roll by itself at idle. It does this in low and reverse. I have had mud/water in my belt housing before I snorkeled it. Could the one way bearing in the primary clutch be going out?? I havent had a chance to brake it down yet but i was hoping I could get an idea of what to look for before i did.
Have you checked your belt good? If you put a flat spot in it, that can cause it to creep on you.
Welcome to the forum!! It could be the clutches are dirty & need cleaning.
If you get a new belt be sure to clean them too!
welcome to the forum!
Seems the common problem for creeping is the belt. Some have expressed having an issue when using certain aftermarket belts. I would try a new belt. It's not like its a waste of money if that isn't it, you will use the belt eventually.
If you installed the spacer & spring in the primary clutch from QSC, take the spacer out. It will cause the bike to creep a tad. I have the exact same kit in my wifes Sportsman and I have the spacer, Adam mentioned if it creeps that I should remove the spacer. I have been to busy to removing. So yeah, mine does the exact same thing as yours.
When I did the QSC kit, I cleaned/deglazed the clutches & installed a new OEM belt.
I will let you know this week when I get some time to remove the spacer if the creep has def. been eliminated.
Thanks for all the reply guys! I going to go buy a new belt today. Hopefully tomorrow or this weekend I will get to break it down and clean them good and see if that works for me bc like I said I covered them in mud/water pretty good before. I will let you guys know if that fixes it.
