From the Gold Eagle site:
MYTH #2: “STA-BIL PRODUCTS DON’T WORK WITH ETHANOL-BLENDED GASOLINE.”
STA-BIL products treat ALL types of fuel—and that includes every ethanol blend, from E-10 to E-85, as well as pure gasoline and diesel. This is widely known in the Midwestern area of the United States, where our manufacturing plant is based and ethanol-blended gasoline has been used for nearly three decades.
The rest of the country is still relatively new to the idea of ethanol-blended fuel, which the government began mandating in recent years to reduce America’s dependence on foreign oil.
The misunderstandings began mostly in warm-weather climates such as the Southeast, where humidity increases the likelihood that water will collect in gas tanks and lead to corrosion. Blended gasoline can heighten this issue because ethanol is an alcohol that absorbs moisture from the atmosphere.
This is especially a concern with equipment that tends to sit between uses, like boats or lawnmowers.
STA-BIL will absolutely work in these conditions,
as long as you have the right formula (see our answer to myth #3, below). Our special
marine formula is made exclusively for nautical conditions, and the daily-use
ethanol treatment (link to post titled “Considering ethanol-free gas? Try an ethanol treatment instead.”) is designed to be used with every fill up.
But they fail to advise you on the right formula other than providing a link to their
Special Marine Formula which is their highest priced. If you read the hype on any of their products they all claim to work with ethanol blended fuel, but on their own website they inform that you must use the RIGHT FORMULA!
Addendum:
From the Gold Eagle Products web site:
“STA-BIL brand additives use a highly-purified
petroleum distillate to deliver our additive package to the fuel. This
solvent allows the additives to quickly blend completely into the fuel. The additives themselves would be too concentrated to blend easily, especially in cold weather. Use of more flammable solvents like gasoline would make shipping and storage too dangerous. The addition of the recommended dose of STA-BIL product to fuel has always been safe. Dozens of Original Equipment Manufacturers (OEMs) have confirmed this by testing and recommending our products.”
Petroleum distillates include gasoline, naphtha, mineral spirits, kerosene, paraffin wax, and tar. They are the primary ingredient in many consumer products, including certain furniture polishes, paint solvents, adhesives, and automotive chemicals.
