Just joined here. I have a '92 Trail Boss 350 and a new (to me) '04 Sportsman 500 6x6.....I was looking for an owners manual for the '04 that could tell me about the digital speedometer....I can't tell what it is trying to tell me. It shows the trip odometer fine, and periodically gives me a flashing wrench....Can figure out how to reset or interpert it.
Kevin
It takes 3 things to get in the kes the shifter and the over ride button.
STEP 1 with key on put bike in park then shift to NEUTRAL
STEP 2. turn key off and hold the override for 10 seconts
STEP 3. while still holdinf the over ride turn key on
that should put you into the control mode
you push the over ride to scroll through the mods and you hold down to reset.
when you get to the wrench hold down and the numbers should start counting up set at 50. that is when you next serice should be.
hop that helps and timming is every thing when you hit it it works if not try again:veryhappy:
And welcome to the board!
