04 Polaris pred 50
Ran fine.. Put away for 2days.. Went to restart and no power..
Checked battey.... 12.7
Checked glass fuse by battery with volt meter... Good
With key on... No power to rear brake light.... No horn.. No starter noise..
Checked power at starter relay.. Jumped red wires across that plug into relay and starter spins..
Checked ohms across rear kill switch and checked fine.. Even wired direct still no brake light..
Will the brake light still light up even if the front kill switch isn't working.?
Shouldn't horn work as long as the key switch is turned on.???
I'm lost and confused where or what to check next...
THANKS IN ADVANCE FOR REPLIES.!!
