Rode the bike this morning, no issues at all. Came in for lunch for about an hour, then started the bike and moved it about ten feet to unload some stuff. Got back on to go hunting and had nothing. No headlights, gauge lights, tail or brake lights, and no starter.
Cleaned battery terminals
Cleaned Starter post terminals
Battery is 13.2
Had one fuse under front panel that was dirty...cleaned it up
Any ideas?
Just went out and checked the ignition switch to see if power is coming to the switch.. and there is now power coming in. Unplugged the stop/run switch and checked it for incoming power... but nothing there either.
Discussion Starter #2
Well.. I found the problem. The wire going from the battery to the switch... at the battery, was corroded in half. Spliced a new wire in its place and its fixed.
