I have a 2006 Sportsman 700 EFI. Replaced fuel pump. Hoses in fuel pump assembly trashed, probably due to ethanol in our gasoline--another story. After putting it back together, it started and ran great with good power. However, the Check engine light comes on. I can reset by restarting, but inevitably comes on again. I have no fuel quantity indication any more on the speedo display. I ran a diagnostic and it reported codes 41 (Air temp senser: open or short circuit to ECU) and 45 (Barometric pressure sensor: circuit low input). Check engine/codes 41 & 45/no fuel quantity indicator--any thing these all have in commor? Have checked almost everything I can find thus far on the forum but can't find a smokin' gun.
Welcome to the board!
Check wiring at t-bap sensor , there are heavy duty kits on e-bay to replace wiring, as for fuel gauge, reach in tank with wire and pull float up, see if it reads full, if it does , float is bad, getting full of gas and sinking to bottom.
Discussion Starter · #6 ·
Nofuel indication
Thanks Treacherous, et al. I will be ringing out the T-BAP harness today. If I have any success, will report it asap.
