1 - 2 of 2 Posts
2002 Polaris Magnum 325 2WD
Both sides of my coil on my Polaris Magnum 325 are grounding. All connections are in the correct place. Brown Wires run to coil. The black wire you see running behind the coil goes to the connection on the bottom. Need help.
139152
139153
OK - well that's messed up, but there is no 'hot' wire running to the coil
The black wire is the kill wire and needs to be removed from the coil - the white wire with a blue stripe goes to the coil where the black wire is connected.
139156
1 - 2 of 2 Posts
