I have a sportsman 1000 xp. Ran great parked for approx 2 weeks now will not start. Went straight to fuse got no power on hot side of fuse. If I send power to fuse it will fire up an run until I take power away honestly I'm a little puzzled any help would be greatly appreciated!!
Did you remove the fuse and check it with a meter or install a new fuse? On occasion, contact to the socket terminals is lost due to moisture and just removing and replacing the fuse will correct the problem. If you checked power to the fuse terminal in the block and have no power, you need to check the #2 fusible link near the battery - it has a blue wire on the battery side and a red wire on the load side - there is another fusible link with a blue wire on the battery side, but it has a white wire red wire with a white stripe on the load side.
sounds like there is no power to the fuse ie line side, correct???
