Hi, I just bought a 2007 Polaris Predator. It has a K&N air filter no air box and i was told its been jetted its also has the exhaust tip removed. It seems to run good in all gears except third, It shifts fine theres no grinding but when I shift into third and start to excelerate the motor starts sputtering and wont excelerate. Is this a tranny problem, dirty carb, bad jet job, a tunning problem or something else? Please help. Its also hard to start and cuts off alot, the carb will make a popping noise and the engine will cut off :cowboy:
sounds like valves need adjusted and carb needs proper jetting. hope over to Polaris Pro Riders tons of help over there.
no problem you just got me at the right time. I dont stop here much anymore since opening up polaris pro riders
im co owner there. I think youll find alot of helpful people and info over there.
