Hello everyone . I have a 2000 Sportsman 4X4 that just lost all power to the Pod ( no light , odometer or spedometer ) as well as the awd light on the handlebar switch. Checked the wire as far as the main ground to the frame goes , and everything is good.The lights all work ( high , low ,and rear tail and brake) . Any help would be appreciated , as I'm a little green at this.
If i were you i'd see if your dealer has a "tester" unit. In the past couple months i've put a few speedo's in. If the speedo goes bad your awd goes with it, as does the lights and odometer.
Thank-you for the quick response. I will see if I can get a tester unit , and check the speedo .
John!
