Have a 2013 Sportsman 500 HO..Full battery and no power all the way to speedo cluster..Turn the key and no display..Changed ignition switch and starter solenoid with no change..Any ideas would really be appreciated..Thanks, forum..
Fuses good??
Power goes from the battery through a fusible link to the #2 20 amp fuse in the fuse block & it jumpers to the #4 5 amp fuse - through the 20 amp fuse it turns into a yellow wire and through the 5 amp fuse it continues as a red wire, this red wire goes to pin #1 on the speedo to maintain the clock and other settings - the yellow wire goes to the key switch where it turns into the red/blk wire - the red/blk wire goes to the LH switch where it turns into a red/wht wire when the stop/run switch is in the run position - from the LH switch, it goes to the AWD switch, the fan switch, #1 20 amp fuse, #3 15 amp fuse, the CDI box, the key switch and pin #2 of the speedo to illuminate the instrument when the switches are on.
Your complaint; no power to the instrument - do you have 12v on the red (pin 1) and red/wht (pin2) on the speedo 16 pin plug?
