my buddy just picked up a 2002 sportsman 500 with 900 miles on it,it will start with the pull start,and run great, but there is no 4x4,lights,dash,or anything electrical at all will work,not even the winch.do you guys have any advice as to what the problem is?
Check fuses, relays, connectors, etc.. It may sound strange but i have heard stories about machines that sat for a long time that actually had mice nesting in them and chewing on things!! If i were you i would start by pulling off some plastics and tracing any wires you can while checking for corrosion or damage..
After visual inspection, if nothing changes get a volt meter and start from the battery and work out from there checking for voltage on each circuit out towards the end.
