1 - 2 of 2 Posts
Need help figuring out what part I need to get for my 99trailblazer 250 to run again someone jumped a hill and broke a motor mount replaced it now it doesn’t have any spark
Start by checking the ground to the engine - if that is not the problem, then unplug the black wire on the CDI - if you then get spark, find the short to ground on the black wire in the wiring harness. Could be the key switch, handlebar switch, throttle safety switch, reverse limiter or damaged wire.
1 - 2 of 2 Posts
