I was wondering if anyone has or has ever used a nos plow mount, #2874815. I hear it Is discontinued and can't figure out how it mounts to my Sportsman 800 Twin. I might buy a universal plow mount later, if I can't figure out how this one mounts. Thanks.
I have not used one , but if you get under your quad and just see how things line up to bolts or bolt holes to see if it will work. I assume you have the push bar that will correctly attach to it ?
I tried that. I can't see how it lines up. It's a center mount. I assume it mounts underneath the ATV. The plow has push tubes.
Did that mounting plate come with the plow , if so who makes the plow blade and push tubes ? That plate mounts right under the engine a little towards the front. Is that supposed to be a universal mount or is it supposed to be specific for your machine. YOUTUBE has a lot of installs on it , if you know who makes it. To give you a idea go on YOUTUBE and type in - Tusk snow plow install . That will give you a look at how a similar plow plate is mounted. Hope that helps you out some.
The picture of the mount you are showing may actually bolt to a seperate plate that mounts to your machine. Best thing is to research the plow manufacturers name .
I've Googled it. I've YouTubed it, nothing. I actually heard it was discontinued. I was thinkong I was missing a plate too. But I haven't seen a plate in the kit.
The mount came with the plow that came with the ATV I bought. I think it is a universal mount. I'm pretty sure its a Polaris OEM NOS center mount. I spent about an hour and a half under the ATV, staring at the bottom to see where the mount fits.
