Help. 1999 500 auto will not come out of gear at an idle. What can be the problem thanks
1. You probably need to turn your idle down. 2.Your belt could be to tight or you could have a problem with your primary clutch. 3. Shift linkage might need to be adjusted.
not going out of gear
Thanks Bruce. Reverse works fine it is acting up in foward high and low. Idle seems fine. Linkage has not been changed. How can I check clutch. The belt has been on for some time and it worked fine. No adjustments have been made to belt. Any help greatly appreciated
