So the fun never ends around here...I just get it to run well enough to use it and now I have a clicking noise from the front right hub.I tried pushing it in neutral and it feels like it binds and then clicks and then lets go,another 10 feet and repeat...I had t apart when I did the lower ball joints not to long ago so I thought maybe I put it back together wrong,tore it down tonight and reassembled,cant find any broken parts,plates bearings,ect.There IS a small amount of tiny metal shavings on the drain plug magnet,do you guys think I screwed up a bearing.This issue just popped up didnt start immediately after the BJ work.Does anyone know the bearing number for the 4 in the hub?Are they all the same?Thanx in advance for any advice you can give me!BTW 2wd,4wd has no effect on the issue.
sounds like a bad cv joint,iI think the hubs are the old school kind on that SPM make sure you have the right kind of oil in them,has to be polaris oil.
Strut bearings and hub bearings are slightly different sizes. Did you use the proper procedure to torque the bearings down correctly?
