I think I know the answer but need verification from someone who knows the Sportsman charging system. The battery is charging intermittently. I've been watching this process over the past few months. What I'm seeing is that when the ATV gets hot (after hours of riding - especially during these hot days) the battery voltage drops dramatically. On 2 occassions it was low enough that the radiator over heated because the fan wouldn't run fast enough.
However after charging the (new) battery each time I get a 14-15 volt charge when the ATV is cool & I rev up the engine. I read that the voltage regulator is located somewhere near the radiator & may not work properly when it get hot. Haven't located the regulator yet. I also understand there is a relocation kit for the regulator that I haven't been able to find yet.
Am I on the right track? Should I replace the regulator? Any help will be appreciated. Right now I monitor the Neutral & Reverse lights when riding and when I see them starting to dim I head back to the garage for a charge if needed!! After an hour ride yesterday evening the battery was still over 12 volts when I got back so the system appeared to be charging.
I'm having a similar issue with my brother's old 400; when I check it, its charging as advertised, but after a long ride on a hot day, the battery is down below 12 volts. Everything checks out and both the battery and regulator are less than a few months old. By the way, the regulator should be mounted somewhere near the front of the radiator.
Thanks for your input. Doesn't make me feel too good, LOL. Once I find the regulator I'll begin a thorough check of the wires back to the battery just to make sure there are no disconnects or breaks.
Found the regualtor and when I went to check the voltage on the red/blk wires the male part of the red wire boke off in the connector. I'm assuming it was hanging on by a thread causing the interimittent charging. I either need to find a replacement connector end or replace the regulator altogether. First I need to figure out how to get access to the screws that mount the regulator.:kabong:
I would lean towards that bad wire being your problem; I would personally repair the wire first and then see if the charging system works with the wire repaired, before buying a new regulator.
Fixed the connector on the regulator and the battery is now charging anywhere from 13-14.5 volts depending on the speed of the motor. Haven't been out long enough to see if heat will affect the regulator yet but all indications show that the connector was the problem. Also cleaned a lot of crap from inbetween the radiator coils that I couldn't see until I took the front cover & deck off the ATV. Also found a mouse or rats nest under the hood and a wire that had the insulation chewed off. :thinking: Never know what you will find when you start digging, LOL.
The only issue I have left is that when shifting into reverse the indicator will sometimes show it's in Neutral and the reverse limiter doesn't engage. Hopefully it's just an adjustment of the linkgage. If not a new shifter box may be in my future. Other than this the machine appears to be working just fine.
Hope this information helps someone else. By the way I couldn't tell there was a problem with the regulator connector until I unplugged the wire.
UPDATE '01 Sportsman charging problem
Need some advice. Here's what I'm seeing
When I first start up the ATV I get the 13-14.5 charging volts across the battery as stated above. Over the weekend I check the voltage after approx 2 hours of riding and only was getting about 11.75 volts across the battery. No increase in voltage when revving up the engine. I let it cool down for about an hour an measured again - got up to 12.75 volts when revving the engine. The next morning when the ATV was cooled down I was getting the 13-14.5 volts once again when revving the engine. Appears to have something to do with heat so I am thinking the voltage regulator should be replaced. Anyone out there think this is the correct solution? Any other tests I should be doing?
Yes, it seems heat related.
Try giving the regulator a quick cool down with a couple of cups of ice water. See if that causes the voltage output to perk back up quickly. If so, yep, its the regulator.
