I have a 2003 sportsman 700. The instrument cluster face has a crack in it then moisture got inside, now no digital display or speedo.
The part number for this is 3280425. This is an obsolete part and no replacement for it.
Is there a way to repair this, or any knowledge of a scrap yard that may have one?
Any other ideas? I know 4wd will not work with the cluster not working.
It would also be nice to have the other info such as battery and if it is starting to overheat.
Plus the gear selection is nice for my granddaughter when she drives it.
Any help is appreciated.
It's a 17 year old dinosaur - time for a new one - if you don't believe me just ask Polaris (n)
The AWD can be made to work without the instrument, but yeah, they build all the interconnects into a single unit and then obsolete the unit. You then have to fix it with used parts until they are all gone then scrap the vehicle. It's life - all things die - some earlier than others.
That unit was part number 3280453 before becoming 3280425 - a good source for used parts is powersportsnation.com or call 402-371-7002
the same unit was used on the following models:
  • 2004 MAGNUM 330 2X4 (A04CB32AA)
  • 2004 MAGNUM 330 4X4 (A04CD32AA)
  • 2002 SPORTSMAN 700 (A02CH68AA/AB/AC/CA/CB)
  • 2003 SPORTSMAN 400 (A03CH42AA/AB/AC)
  • 2003 SPORTSMAN 500 HO (A03CH50AA/AB/AC/AD/AE/AH/AJ)
  • 2003 SPORTSMAN 600 (A03CH59AA)
  • 2003 SPORTSMAN 6X6 (A03CL50AA)
  • 2003 SPORTSMAN 700 (A03CH68AA/AC/AF/AH/AL)
  • 2004 SPORTSMAN 6X6 (A04CL50AA)
Thanks for the information and reply.
