I have a 01 sportsman 500. I have 15 volts at idle but when I begin to rev it up the voltage drops fast and the lights barely light. the battery does not seem to hold a good charge so I bought a new one I just don't want to fry the new one right off the bat. any ideas?
Welcome to the board!
put in the new battery, no problems with voltage drop anymore. seems to maintain a constant voltage at any rpm now. guess time will tell.
THANKS
The battery is a primary part of the charging system. It acts not only as a big pot to hold charge but also lets the regulator know how much voltage to send. You experienced what people have found out when they try and run without a battery and that is over voltage. You just didn't have to replace all your bulbs.
