I'm of paying the dealership for oil changes. Can anyone tell me how to properly change the oil. Do have to prime the sump? And all that other good stuff. Please any info will help
Stealership will not tell me anything.
I prime the sump every change. If you have never done it before, may be an idea to pull the right running board, will make it easier to remove the crank plug.on my 400ho, i can put a 14mm box end wrench up through the hole in the skid plate.
See the plug above and left of the date stamp? That is the crank plug.
An awesome video done by Jordan, a site member.
I run a Car Quest (Wix) filter, and Quaker State 5W50 in mine.
Thanks,
Will
2012 Sportsman 400HO.
How do you prime the sump?
Was it in the video? On the top of the oil tank is a hose with a slit in it. Use pliers or vise grips and squeeze the hose 2"!from the oil tank, start it up, let it run for 20 seconds, then release the pliers/vise grips. You do this on the right side of the tank,
Thanks,
Will
Thanks will. My phone will not load the YouTube video. When I get home I will watch it . again thanks for the help and info
