So glad you asked that question. I have a 98 model, and I'm looking for the same info.
I found this information online, but is it true?
FRONT GEARCASE OIL
Polaris Premium Hub Drive Fluid (#2781654)
Substitutes:
Amsoil Automatic Transmission Fluid (ATF)
Amsoil STL Shock Therapy #5
Any Type F ATF
Dextron III Trans fluid
TRANSMISSION OIL
Polaris Premium Synthetic Gearcase Lubricant (#2783602)
Substitutes:
Amsoil Series 2000 Synthetic Chain Case Oil (TCC)
REAR GEARCASE OIL
Polaris Premium Synthetic Gearcase Lube (or GL5 80-90 weight gear lube)
(I assume the stock fluid is #2781653, Gear Drive Fluid)
Substitutes:
Amsoil 80w-90 Synthetic Gear Lube (AGL)
Amsoil 75w-90 Severe Gear Lube (SVG)
MY COMMENTS ADDED IN [[[ ]]]]
FRONT GEARCASE OIL
Polaris Premium Hub Drive Fluid (#2781654) [[ I FOUND THIS TO BE #2876160 & THE MANUAL SAYS #2871653 ]]
Substitutes:
Any Type F ATF
TRANSMISSION OIL
Polaris Premium Synthetic Gearcase Lubricant (#2783602) [[I FOUND THIS TO BE #32878068 & THE MANUAL SAYS #2871478 ]]
Substitutes:
REAR GEARCASE OIL
Substitutes:
[[ I FOUND FRONT HUBS TO BE FROM TEH MANUAL #2871654 ]]]
