1 - 1 of 1 Posts
Magnum 330
Received oil cooling hose for replacement. There were three [all different types] washers and one O-ring loose with the packaging. When I removed the defective oil hose, there were no washers or O-ring. Do I need them ?? perhaps an improvement ?? if so where does each type washer go? The Polaris service manual diagram does not indicate that there are any washers or an O-ring from the cooler to the engine block. Can someone advise?
1 - 1 of 1 Posts
