This last weekend I rebuilt my carb and removed the factory airbox and replaced with an uni filter directly attached the carb. I left the breather hose coming from the crankcase just hanging out back. Everything started up and idled fine but as soon as I gave it any throttle a LOT of oil started gushing out of the breather hose all over the ground.
I read a lot on the forums and only thing I can find is people saying the crankcase was overfilled during oil change. I know how to check the oil level when its warm and I have probably rode the quad 3-4 hours since last oil change and no oil was in the factory airbox when I removed it.
I do plan on putting a little filter on the end of the breather hose and securing it near the back. Quad felt super powerful before I did all this so I really doubt I have a ring issue causing excess crankcase pressure but I do plan to do a compression and leakdown test just for giggles.
Anyone have any other suggestions?
2006 Polaris Predator 500 TLE
to the forum
If the oil was gushing, the engine was either overfull of oil or you have excessive blow-by into the crankcase. If the oil was a large quantity of droplets, I suggest you install a baffed oil trap and install a crankcase oil return line onto the clutch cover.
