Has it ever been rolled over?I have a 02 Sportsman 500 that I discovered oil in the air box deep enough that it was up to the filter. Any suggestions on what is wrong with it is much appreciated
Yes probably within 10 hrsIt was like no oil the last time you looked then all that oil appeared?
The project Magnum had oil in the box but the guy had a hose dumping oil until it went to knocking. Since we use ours on shore I just keep the drain hole unplugged.
ThanksWelcome to the board!:med:
Thanks but I have the correct amount of oil in it. The oil tank also vents to the air box and that line was wetOil in the air box on a 500 can come from Too much oil in the crankcase, the engine is vented into the air box.
