I have a 2009 Sportsman Touring 800 EFI and I notice that I'm frequently low on oil. I don't see it leaking anywhere and the exhaust is clear. I have noticed there is quite a bit of oil in the cold air box. I do regular maintenance, and it's never been like this before, there is standing oil in the bottom and the whole inside of the box is covered in a slimy film.
I'm wondering if it has a PVC valve like a car, maybe that's faulty?
Jason -lost of performance , oil consumption, oil in exhaust, noises.....the engine is most likely slowly breaking up (eating itself). Don't drive it and get to a reputable repair shop for a compression test, leak down test and a good opinion. The more you drive it the worst it becomes. Your going to have make some tough decisions but never fall in love with gas, oil and tires. Why do I know.
Suggest you save your Canadian coin and try to spend those repair CA's on a newer machine. Maybe one in that reputable repair shop! Good Luck
There was a crank vent upgrade for those older twins due to oil in the air box issues. Might want to check on that too. I was just saying to check compression first. It only takes a few minutes and you can borrow a compression gauge at most any auto parts store. If its low a new set of rings and gaskets and you'll be almost good as new.
I'm going to pick up a compression gauge tomorrow. Ideally, how much compression I should see?
Is replacing the rings and gasket (I'm assuming that means head gasket) difficult? I consider myself mechanically inclined, but it seems a little intimidating.
Polaris 2008 sportsman 800efi Manual Online: fuel system, Electrical, Vent Lines, Compression Test. Warning Gasoline Is Extremely Flammable And Explosive * Under Certain Conditions. * Efi Components Are Under High Pressure. Verify System Pressure Has Disassembly. * Never Drain The Fuel...
how is your air cleaner ??
if air filter is plugged with dirt and dust ... machine cant get air ... so it will suck air up thru breather tube along with oil mist ....
been there done that ....
Related Threads
876.5K posts
113.4K members
Since 2008
