picked up a 400 sport and i want to play it safe so i want to delete the oil injection and premix myself.ive read a few thoughts on this and theres 2 ways to go about this
1)buy the block off plate and rejet
2)simply discconnect the line and mix 32:1,no jetting
which is the best way to do this?i talked with my local polaris dealer and they simply stated a block off is all thats needed.they said that i would need to go up one jet size with a new pipe but thats it.
could someone lay all this out as simple as possible?
ok so the project has started.2 things im still stumped on.
ive decided to use a block off plate,do i have to install the single cable conversion?or is it strickly for a smoother throttle?and if do install the single throttle cable,is there a trick to getting it adjusted correctly?
97 scrambler manual
I have a 700 page service manual on dvd if some one would like a copy you pay for shipping and i will make you a copy
