Noticed a small oil leak from the block. When the engine warms up, it will leak right from the corner. It appears that it will blow out and suck back in. It will leak more when the breather in the airbox is covered and opened... It is on clutch side above the oil lines. Anyone else have this problem?
Not sure what to do. Complete tear down or external fix. Leak is about a droplet every minute. Not a whole lot, but enough to notice.
Anyone know what a dealership would charge? Or what a solution to this problem would be.
Thanks in advance! More photos if needed.
2008 Polaris Sportsman 500 EFI
