Hi guys name is Brendon I'm new to the forum, recently bought a 98 xplorer 400 with no compression so a new piston rings and cylinder later had it runnin. After couple minutes of idleing noticed crank case vent was puking out milky oil. So coolant is getting in oil some how I assume water pump gasket? Is this a common problem on this machine? Any help would be appreciated
