Hi All.
Hoping that someone can help with an oil issue. Was getting ATV ready for winter and decided to do oil change, front/rear oils. lubrication, etc.....
After draining the oil and changing filter I added approx 1.9L of 0W40 oil, checked the dip-stick and noted above the "full" line....started machine and let run for 20 sec or so then shut off....checked oil level and was still way above the "full" line.....noting this I tried the oil pump priming procedure (released vice-grips with machine running) but did not hear the release of any air. Tried a total of 5 times and nothing, oil still above the "full" line.
I have changed the oil 3 times prior and never had a problem, oil level would drop after starting, just not this time.
Any thoughts or tricks-of-the-trade?
Dont want to run engine too long if oil is not getting in there.
Thanks in advance.
what a pecker head.....me not you.
No I didn't.......
Will drain sump/crank to fill level on stick.
I would think if there is oil in the filter, pump is working correctly.
Agree?
No I didn't.......
Agree?
Yupp, if the filter has oil in it, should be primed.
The air gush must be quiet, i have never heard it myself, and a I prime each oil change.
I kinda clumsy, so I pull my right running board each change, makes getting the plug out easier.
Thanks,
Will
2012 Sportsman 400HO.
