1 - 11 of 11 Posts
Discussion Starter · #4 ·
Will. There are 2 options for 2002 built before 1-2-02 uses aluminum. After 1-2-02 uses plastic. My plastic one leaks at the drain plug. If you tighten it the brass insert separates from the plastic and drip drip drip. Plastic is like $140. So replace it with an aluminum and problem solved. I just want to know if it will work.
Thanks again Will
Yes it will, do a search on here, there is one thread.
Thanks again Will
Thanks,
Will
2012 Sportsman 400HO.
Will. Not an idiot. But I have search threads with every key word and phrase I can think of. I cant find it. Any help?
The search feature sucks!! I've searched all kind of stuff and never find what I want! I c nothing wrong with posting questions even if they have been asked before Bc if all people did was search and get there answers this site would be dead!!
2013 850ho
2013 850ho
I cant search from my phone, never any luck. I will do a search and post here.
Thanks,
Will
FleeBay. Cheap. Pre 2001. Split open and clean any used tank. There was over an inch of sludge with small metal flakes in the two I bought.
1 - 11 of 11 Posts
