1 - 2 of 2 Posts
hello iam new to this forum. i have gotten alot of useful info from you guys iam greatful. i bought a 1995 sportsman CHEAP.I bought a new starter and solenoid.i have 4 wires on the old solenoid 2 big and 2 small the two small ones are red and red and white.my new solenoid only has one small hookup. how do i hook up the new one? thanks
This should work. With a test light or multi- meter determine which of the small wires is hot when the stater is supposed to be engaged. Connect it to the small terminal on the solenoid. The other one may be a ground and if it is and your solenoid is not attached to the frame then you will need to hook it to the mounting tab of the new one. If the old solenoid is mounted to the frame then you will not need it
1 - 2 of 2 Posts
