1 - 1 of 1 Posts
· Registered
Hi All,
I have a 2008 Polaris Outlaw 525 IRS that I cannot get to idle consistently. I have cleaned the carb really well and have recently replaced the throttle cable. The problem existed before the new cable so I do not suspect that this is the issue. The reading on the TPS sensor through the yellow and black wires is currently set at .704 k ohms and at 5.21 through the black and blue wires. I cannot find anything that tells me what the specs should be set to so I cannot verify if its correct or not. I also put a new spark plug recently as well so I am starting to run out of ideas. Any help would be greatly appreciated.
Thank you,
KCJoe
1 - 1 of 1 Posts
