Hello,
Exhaust of Outlaw 525 irs fit Outlaw 525s?
It's the same exhaust?
I have the s model,the exhaust of IRS will match 100%??
can i order exhaust for IRS and it will fit to my s model?
the Sportsman 500 2000, came in with a no running problem, found stator no production of voltage, took cover off and hand start mechanism had fallen apart and was shrouded and broken the plastic and metal in 100 pieces and tore up the stator assembly. I replaced it with a new assembly also it...
I have a 17 sportsman highlifter and was wondering if anyone had done the reverse override mod. I’ve found threads on older models but didn’t know if anyone had done it to newer models. Thanks for any reply’s and information
Hello to all, I have a 17 570 hunter. And I would like to install a larger capacity fuel tank. Dose anyone know or have installed the 6.75 gallon 570 turing tank in the sp hunter?
Thank you in advance..
