My son's 2008 Outlaw 90 has an electronic throttle control (ETC) that ties into some type of rev limiter which will significantly limit power output when the throttle lever is released in a stuck throttle situation or when in reverse. The switch in the throttle assembly went bad last year and I bypassed it since the switch could not be replaced without ordering the whole throttle lever assembly ($105). It has been running fine until this weekend at Glamis, the engine runs but power is reduced so much it won't even move. I confirmed the soldered wires that bypassed the ETC switch are still connected.
Is there a way to bypass this entire electronic feature and do away with the component that is cutting power? Someone mentioned to me that I may be able to replace the CDI box with an aftermarket one that will do want I want. Any ideas?
Any other suggestions to get more performance out of this quad?
