My 06 700 idles fine 1150-1200rpm,,seems to pull away okay but is reving way too high. Its at 5500 at 30mph,,,, and tops out @ 6400 at 40mph.
Can this just be a worn belt? Stk clutch 2300 miles and 27 inch tires.
Belt looks good without measuring it.
Sounds like an issue with the belts and/or clutches. I would start by changing the belt. You might also want to look into a clutch kit as well since you are running oversize tires.
