21 - 32 of 32 Posts
Discussion Starter #23
I've tried to search. That's the cheapest stator I've seen that seems to still be worth it. It looks exactly the same as mine but the info in that link says 2009-2015 850 stator. There should be no difference for the 2016 850 stator correct?
Assemblies where 4014006 is used:
2013 850 SCRAMBLER HO EPS INTL (A13GH8EFK) - Electrical, Ignition System
2013 850 SCRAMBLER HO/EPS HO (A13GH85AJ/EAK) - Electrical, Ignition System
2013 SPORTSMAN FOREST 850 (A13ZN8EFK/EFN) - Electrical, Ignition System
2013 SPORTSMAN TOURING 850 EPS INTL (A13DN8EFW) - Electrical, Ignition System
2013 SPORTSMAN TOURING 850 HO EPS (A13DN8EAF/EAL/EAR) - Electrical, Ignition System
2013 SPORTSMAN XP 850 (A13ZN85AA/AQ/AZ) - Electrical, Ignition System
2013 SPORTSMAN XP 850 HO EPS (A13ZN8EAD/K/L/T) - Electrical, Ignition System
2014 SCRAMBLER 1000 XP HO EPS INTL (A14GH9EFW) - Electrical, Ignition System
2014 SCRAMBLER 850 XP HO/EPS (A14GH85AD/EAI) - Electrical, Ignition System
2014 SCRAMBLER XP 1000 HO EPS (A14GH9EAW) - Electrical, Ignition System
2014 SCRAMBLER XP 850 HO EPS INTL (A14GH8EFI) - Electrical, Ignition System
2014 SPORTSMAN 850 WV (A14YN8EAJ/EAT) - Electrical, Ignition System
2014 SPORTSMAN FOREST 850 (A14ZN8EFP) - Electrical, Ignition System
2014 SPORTSMAN TOURING 850 INTL (A14DN8EFQ) - Electrical, Ignition System
2014 SPORTSMAN TOURING EPS 850/HO (A14DN8EAH/EAQ/EAR) - Electrical, Ignition System
2014 SPORTSMAN XP EPS 850/HO (A14ZN8EAB/C/I/M/P/S) - Electrical, Ignition System
2015 850 FOREST EU (A15SXE85FI) - Electrical, Ignition System
2015 FOREST 1000 EU (A15SXE95FK) - Electrical, Ignition System
2015 SCRAMBLER 1000 MD (A15SVE95HW) - Electrical, Ignition System
2015 SCRAMBLER 850 (A15SVA85AD) - Electrical, Ignition System
2015 SCRAMBLER 850 EU (A15SVA85FD) - Electrical, Ignition System
2015 SCRAMBLER 850 MD (A15SVA85HD) - Electrical, Ignition System
2015 SCRAMBLER XP 1000 (A15SVE95AW) - Electrical, Ignition System
2015 SCRAMBLER XP 1000 EU (A15SVE95FW) - Electrical, Ignition System
2015 SPORTSMAN 1000 MD (A15SXE95HK) - Electrical, Ignition System
2015 SPORTSMAN 1000 XP (A15SXE95AC/AK/AW/L95AM) - Electrical, Ignition System
2015 SPORTSMAN 1000 XP (A15SXE95AC/AK/L95AM) - Electrical, Ignition System
2015 SPORTSMAN 850 SP (A15SXE85AS/AM/A85AA/AC/AJ) - Electrical, Ignition System
2015 SPORTSMAN 850 TOURING SP EU (A15SYE85FS) - Electrical, Ignition System
2015 SPORTSMAN 850 TOURING SP MD (A15SYE85HS) - Electrical, Ignition System
2015 SPORTSMAN TOURING 1000 (A15SYE95AX/L95AP) - Electrical, Ignition System
2015 SPORTSMAN TOURING 850 SP (A15SYE85AS/AV) - Electrical, Ignition System
2015 SPORTSMAN XP 850 HO EPS MD (A15SXE85HI) - Electrical, Ignition System
2016 SCRAMBLER 850 (A16SVA85A2) - Electrical, Ignition System
2016 SCRAMBLER XP 1000 (A16SVE95AA/AM) - Electrical, Ignition System
2016 SPORTSMAN 1000 HL (A16SXM95AL) - Electrical, Ignition System
2016 SPORTSMAN 1000 MD (A16SXE95NK/A95N2) - Electrical, Ignition System
2016 SPORTSMAN 1000 XP (A16SXE95AG/AR/D95A9) - Electrical, Ignition System
2016 SPORTSMAN 1000 XP, TRACTOR (A16SXS95CK/CG/T95C2) - Electrical, Ignition System
2016 SPORTSMAN 1000 XP, TRACTOR (A16SXS95CK/T95C2) - Electrical, Ignition System
2016 SPORTSMAN 850 HL (A16SXN85A3) - Electrical, Ignition System
2016 SPORTSMAN 850 SP (A16SXE85AS/AM/A85A1/A2/A9) - Electrical, Ignition System
2016 SPORTSMAN 850 SP (A16SXE85AS/AM/AB/A85A1/A2/A9) - Electrical, Ignition System
2016 SPORTSMAN TOURING 1000 (A16SYE95AK/AP) - Electrical, Ignition System
2016 SPORTSMAN TOURING 1000 MD (A16SYE95NK) - Electrical, Ignition System
2016 SPORTSMAN TOURING 850 SP (A16SYE85AS) - Electrical, Ignition System
My machine does the same thing but I replace the battery and the regulator and it didn't fix the problem. Ideas?
First off what are you working on??? How are you testing "over voltage"???? It might be your stator, that would be my next test. Assuming the battery and VR are actually good!!!
Over voltage displays on screen along with climbing numbers.
Ovr v 0.1
That's how it displays and number goes up from there.
Replacing stators will fix under voltage problems, but not over voltage problems - rec/reg corrects over voltage problems unless the stator is shorted to ground and back feeding AC voltage to the battery in which case the voltage can be detected as high and at the same time discharge the battery - batteries don't like AC
my Stator is grounding. I do have a stator from a 09 850 xp but the part# is different from the 2015. Can anyone tell me why the 09 won’t work in my 15 ?
21 - 32 of 32 Posts
