Hello All,
I am new here and hoping for a little help.
I have a 2002 Polaris sportsman 400 and my fan is not working, I do know the fan is ok as I have tested, I also know my temp sensor (on the engine) is not working. My question is does that sensor have anything to do with the fan? I believe that sensor only controls the temp light but just looking to make sure.
If that sensor only controls the temp light I assume the problem is the temp sensor on the rad.
Any help would be appreciated.
Thanks.
The temp sensor is nothing more than a switch. As it heats up it closes at a defined temperature. Can be tested with a multimeter. If it is not closing when it gets hot then it's bad.
