1 - 2 of 2 Posts
My new ATV is in. I am like a little kid on Christmas. During the winch install I took off all the seats. When I went to put back on the rearmost passenger seat, it would not latch. I sat on it, pulled backwards, took it off and made sure the post latch was not bent, put it on without the front seat on. Bottom line, it was a no go. Just in case any other new ATV owners have this problem, I took off the post the seat latches onto and took a very thin piece of rubber. I made a soft washer and put the small notched post back on with the thin washer between it and the mount (that attatches between the shock and the front hinge). It probably added less than a sixteenth of an inch difference, but raised the post enough the latch would finally grab. The seat latches now and is tight and firm. The seat still has some side to side play due to the design, but latches a thousand times better. Just thought I would pass this on. Happy riding.
1 - 2 of 2 Posts
