1 - 2 of 2 Posts
Forgot to take pic of location of the fuel lines connecting to the back of the petcock. It is an outlaw 90. Anyone tell me where line for has tank connects, etc.
Tony
It's pretty simple - the fuel line lowest on the tank is reserve - with the tank drained, pour about a 1/2 to one pint of fuel into the tank (you want fuel to run out one line but not the other) - the line fuel runs out of first is reserve - with the petcock in the reserve position, connect the line to the spigot that causes fuel to flow out to the carb (you can test by putting the line on the other spigot and switch to on - fuel should again flow - the spigot for on will flow fuel when the tank is filled to the point the upper spigot on the tank is below the fuel level.
1 - 2 of 2 Posts
