Hello everyone! Glad to join the forums!
I have a Phoenix 200, I believe its a 2008. Last year I had the carburetor replaced along with a few other things. It ran nicely until I stopped using it for a couple of months. I forgot to treat the fuel and it was just left sitting for about six months. I went to go start it the other day and it didn't start so I took out the carb and cleaned it up. Not only this, but I checked the spark plugs, oil, etc. Now when I try to start it, it doesn't actually start. If I spray some carb cleaner into where the air filter hole is, it starts up for a second, but I don't think its getting fuel. I recleaned the carb today however and when I opened it there was fuel sitting in there, so I'm not quite sure what the problem could be. Any help would be greatly appreciated! Thank you!
How long did you soak the carb in the cleaning solution?
Not too long when I took it out. About 2 minutes. However, I took out each piece individually and sprayed them all down, along with spraying inside all the holes and such. Nothing seems to be clogged.
I use a heated commercial cleaner and it takes 20 minutes or longer to clean things thoroughly - spray cleaners are good for surface dirt but are like using water to take tar off a rock on the hard fuel residues inside jets and internal carb passages. I used to use a commercial cold parts cleaner ($35 for a gallon about $145 for 5 gallons), but quit using it when I saw the results of the heated sonic cleaner with a specific cleaning solution for cleaning white metals.
Oh, definitely good to know! I'll be trying that out tomorrow. Thank you for your help!
