i mounted the kolpin stealth exhaust and not sure if i have it set up right on my 2012 sportsman 500. its a little quieter but i havent put on the heat shield im not sure how or if i need to. this is how i have it, the black paint has started to wear or melt away to a silver color from the heat where that drip is on the exhaust. is that bad? lets see your set up
IDK - that discoloration looks like it is from heat buildup right at the exhaust of the stock muffler? I'm not sure if that is good or not. Why don't you contact Kolpin Support and ask them to have a look at the pic - I would definitely ask about the discoloration. I would want to keep track of the exhaust temp at the engine head pipe, in case that thing is causing back-pressure and additional exhaust heat at the motor. Just my thoughts.
