On my 98 Magnum 425, would it make sense that there is a brass cap covering my pilot (air) screw? If so, how do I remove and replace it?
Yes..... they are usually capped at the manufacturer. Drill a tiny hole in the center and turn a "screw" into it a bit , then use pliers to wiggle it back and forth till it comes off...........
