So I have cracked plastic on my rear rack cover...any options to make this look better and be a bit more functional? I'd rather spend money on steel versus the $257 for the factory plastic cover.
I don't know how severe the crack is on your machine, but if it's just a split like crack with no plastic missing you can always Frankenstein it like I did my John Deere hood on my X300. :smile
Just took my brand new 2012 850 EPS XP out for a easy 50 mile ride. Right away I noitced a rather loud "wa wa" noise. Noise was so bad that I almost turned around and put it back on the trailer. After a few miles the noise diminished, but never went away. Noise comes on at 21 MPH which I can...
hello all,
Im going to be putting 27s on after the stockers bite it and im wondering what clutch kit i should buy. Something that will be fine with the stocks and the 27s when installed. EPI? HL?
Hi everyone. I have an 09 850 with 500 hours . I am wondering if anyone has found a big bore kit that is nice and rideable, but gives noticeable improvement. I have a QSC kit for this an a Magnum chip. I see JE makes pistons for this. Has anyone tried these? How much will this give? Can you use...
I was out riding on Saturday, and after coming down a large hill I noticed that shifting gears had become nearly impossible. At first I thought maybe the linkage had come loose, but after tearing the plastics off everything is till tight. If I turn the key to on, but don't fire the engine, I can...
