I installed a new carb, its a Mikuni BST34 like the quad came with. The old carb had issues that I couldn't resolve with a rebuild kit.
Currently, the Pilot jet is 40 and Main is 165. The E-Clip on the needle is on the 3rd ring as specified by the service manual.
It starts up no problem, even when cold it'll start within two or three turns. It idles nice and low and seems to react to throttle without hesitation. The problem is with the throttle wide open, it bogs down. Holding the throttle wide open, the engine will rev up and then start to bog down, get slower and then speed up momentarily and then sorta sits somewhere between slowing and rising. I'm also hearing popping from the exhaust. When I let go, it'll come back down to idle and just sit there, it won't shut off.
When I started this carb swap, I also put in a new spark plug. The old one looked white as though it was running lean and the engine had problem idling. I'm guessing it was fouled.
At the moment, it'll idle really well, wont choke out. It'll react to throttle well but bogs down at full throttle and pops in exhaust if I hold the throttle.
Any help would be appreciated, I'm getting tired to taking the carb out to swap main jets. I have on hand 155, 160, 165 and 170.
One other thing I noticed, when I take off the air box and run it without it, I notice a mist of fuel blowing back out the intake under higher rpm's.
