I bought a used Sportsman 400 today, not running, year unknown. The seller said he got it in a trade for firewood and was never able to get it to run. Other than the plastic being faded, its actually in really good shape.
Here is where I am at with it, I was hoping someone could help me out...I can get it to turn over by pushing UP on the red Off-On-Off Switch (that took me a while to figure out!), but it doesn't seem to want to fire. I tried fresh fuel and made sure the petcock was ON and also tried starting fluid into the intake, no fire.
They had an on/off switch wired from the battery area to under the pod going into a white and white/red connector.
They also did some "work" on other wires under the pod...
I removed the switch because it didn't seem to have any effect on anything.
I also noticed this. It looks like a fuel filter or something but I have no idea what it is. It goes into the airbox and the black hose before it seems to be cut. When the engine is trying to turn over I can see the black hose flapping around. Is that some sort of vent for the crank case?
I do have working taillights and headlights, with the key on, but everything else in the pod seems dead as can be. The oil tank had a good level of oil which was nice to see.
I don't mind putting some money for parts and a lot of time into this as a project, but I have no idea where to even begin. Any help would be greatly appreciated. I don't even know what year this one is. I'm guessing 2000ish?
Where do I even start!?
Thanks!
Thanks!
