1 - 14 of 14 Posts
· Premium Member
Toy Gesture Art Fictional character Baby toys
· Premium Member
Font Line Window Pattern Screenshot
to the forum
Ball Gas Font Vehicle registration plate Automotive lighting
· Administrator
Do you have 12v on the red/wht wire at the CDI unit? If yes, do you have continuity to ground between the black and brown wires at the CDI unit?
· Administrator
Throw parts at it all day and if you hit the bad connection it wight work again, but what will you do when it happens again? I prefer to fix the problem and not the symptom.
90% of all electrical problems are connections and 90% of all connection problems are grounds
· Registered
Stator shouldn't be going into the CDI box! You probably cooked it if you managed to get it plugged in ... :eek:
Stator is for charging. The 3 yellow (or white) wires all put out AC voltage - quite a bit of it at higher RPM. That should go directly to the regulator. And neither of these components have anything to do with ignition whatsoever. There's a pickup coil down in that area that DOES , though - those put out about 1 ACV to tell the CDI box when to spark.
· Registered
I have a 2005 sportsman which had the same problem. Pulled the front body off to get a better look at the wiring. Found a broken white wire. Where it went I have no idea. Put the wires back together and the problem was solved.
1 - 14 of 14 Posts
